Turned engine removing balancer bolts, will timing be off installing opti?
Old Jun 7, 2007 | 02:58 AM
97ws6togo's Avatar
Hey all. I removed my crank pulley, and while i did this i turned the engine a little bit removing the bolts on the balancer. I approximatley know where the location the arrow was pointing to before taking it off. When i put back on my distributor will there be a problem with timing? I have a 97 stock trans am automatic.
Old Jun 7, 2007 | 03:45 AM
throb's Avatar
Should be no issues with timing being off. The cam is driven off a chain from the crankshaft and they turn together. The only time turning the crank alone would be an issue is if you had that chain removed.
Make sure you get the arrow on the balancer at the same place when you reinstall the balancer though. It should be pointed at 12 o'clock with #1 piston at TDC. The balancer may have been trimmed a little from the factory.
Old Jun 7, 2007 | 06:30 AM
wrd1972's Avatar
You are totally fine.
Old Jun 7, 2007 | 02:46 PM
97ws6togo's Avatar
thanks guys, that helps a bit. appreciate it.
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
