Turn Signals Inop
Old Oct 3, 2025 | 03:41 PM
RUDEDOG's Avatar
Turn Signals Inop
Turn Signals Inop. 4 way flashers work so I assume fuse is good. Any ideas?
Old Oct 3, 2025 | 04:07 PM
Re: Turn Signals Inop
Separate flashers for turns and 4-ways. Separate fuses.
http://shbox.com/1/flashers.jpg
1995 4th Gen F-Body Exterior Lights
Old Oct 3, 2025 | 05:02 PM
RUDEDOG's Avatar
2 separate flashers thanks for that. Fuse was blown after 30 years. Good to go for now thanks.
Old Oct 10, 2025 | 08:49 AM
RUDEDOG's Avatar
Replaced flasher. No help. Operated turn Signals while inspecting and shaking down wiring and fuse didn't blow. As soon as I started engine fuse blew. Still troubleshooting.
Old Oct 12, 2025 | 03:21 PM
I can’t seem to access the Shoebox schematic I linked above. As I recall, the schematic showing the fuses indicates there are one or more additional loads on turn signal fuse, as indicated by an arrow pointing off to the left, with a reference to the next drawing page number. You need to look to see what other loads are on that fuse.
Old Oct 13, 2025 | 01:41 AM
RUDEDOG's Avatar
Thanks that might be helpful!
Old Oct 13, 2025 | 09:33 AM
Do you have the 1995 factory service manual?
Free download:
https://www.mediafire.com/?40mfgeoe4ctti
Old Dec 9, 2025 | 09:46 AM
RUDEDOG's Avatar
More info. Back up lamps are also on same circuit. Fuse blows when shifting to reverse. Next move isolating switch on trans. Progress
Old Dec 13, 2025 | 01:56 PM
RUDEDOG's Avatar
Ok just to bring this thread to the fix. I replaced the Reverse Light Switch (Was the Fuse blower) on the Transmission. Turn Signals and Reverse Lights ops ck good now. Installed some LED Reverse Lights too just because.
Old Dec 14, 2025 | 10:53 AM
98BackinBlack
Nov 27, 2007 02:32 PM
Campbell45
Jun 29, 2007 02:11 PM
CrAkD X 95TA
May 14, 2005 12:44 AM
95TA8280
Nov 9, 2004 11:29 AM
Z28 Tweaker
Feb 20, 2003 07:26 AM
