Turn Signals
Old Nov 18, 2003 | 12:18 PM
RK95B4C's Avatar
Turn Signals
Hi.
My son has a '95 T/A. Turn signals slowed down to a crawl a week or so ago. Hazards continued to work fine. Now everything has gone dead.
The local Midas changed out every bulb, checked flashers, and now ordered/installed an $80 part yesterday.
Turn signals worked for a few hours; today no good.
Anyone experience this and know what the root cause/fix is?
Old Nov 18, 2003 | 12:21 PM
Heatmaker's Avatar
Advanced Member
Is there any water damage present? Or has anything been wired to or connected to the Turning lamp wires? just sounds like a bad relay to me.
Old Nov 18, 2003 | 01:58 PM
RK95B4C's Avatar
turn signals
Thanks, is a "bad relay" the same as a control switch?
That's what they installed after diagnostics claimed this was the issue.
We're waiting to see/hear what happens.
Old Nov 18, 2003 | 08:28 PM
Bud M's Avatar
The flasher control unit is not in the fuse box under the hood. It's under the driver side kick panel to the left of the steering column.
I know someone else whose Z28 is doing the exact same thing. We have changed the flasher and that didn't fix the problem. Keep us posted, okay?
Old Nov 18, 2003 | 10:12 PM
Spinner's Avatar
A low battery voltage will also slow them down.
Old Nov 18, 2003 | 10:46 PM
AW/whiteZ-28's Avatar
Actually the flasher to the left of the steering column is the hazards the turn signal is the one to the right that's stuck into the dash itself
EDIT: Never mind I just noticed he drives a TA I dunno
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
