Turn signal switch question
What exactly makes the turn signal lever stay in one position until you turn? I have a car here that when turning left it is fine, but the lever won't stay in the turn right position. It will not pass inspection because this, is this something I can attempt to fix?
Bill
Bill
Re: Turn signal switch question
You will probably have to replace the switch in the column or there might be a part in there that is broken. At any rate, a teardown of the column is likely in order.
stangspank
Nov 13, 2015 01:02 PM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
