Turn Signal Problem
Turn Signal Problem
My left Signal works perfectly. Right one, intermittently. Noticed a couple things though. If I quickly turn the left signal on, and then quickly goto right signal, it will almost always work. Also, if I have just the fog and dash lights on (Switch to middle position) Right will not work at all, unless I do the left to right quickly thing. Or if I turn the Fog, and dash lights off. If I turn right signal on, and it doesn't work, and shut off my Dash lights while the signal is still on, it will start working. Also noticed, when break lights are on for example, the right side is alot dimmer than the left side. All three bulbs. Now, I have added sequential flashers to both sides, but I don't think they are the problem, as it seems others have the same problem. Some insight on how to fix this would be greatly appreciated. I would like the one side to be as bright as the left, also Im working on selling my car right now, and fixing this would help things out!
stangspank
Nov 13, 2015 01:02 PM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
