tuning required for 58mm throttle body? holley problems?
Old Jun 22, 2007 | 04:37 PM
96LT1TX's Avatar
I was wondering if I would gain any hp on adding a 58mm Throttle body. I still have the stock 48mm on my 383 and definitly need to upgrade. If I could do this without updating my PCM I could do this sooner than later. I was also wondering if I would see any more gains on say a BBK or an AS&M 58mm TB over the holley. I will be getting tuning software but I will also not know what I am doign with it at first.
Old Jun 22, 2007 | 04:56 PM
Vicious95Z28's Avatar
No tuning needed with an M6
Old Jun 23, 2007 | 11:51 AM
You will need to verify idle RPM, IAC motor counts and TPS closed throttle voltage when you do the install.
Old Jun 25, 2007 | 12:38 PM
96LT1TX's Avatar
can these be checked with just a datalogger? And I guess if they are off I will need LT1_edit to fix them then huh... I plan on getting LT1 edit by the time I do this so I hope those arent that hard to change if infact they are different.
Thanks for the replies
HectorM52
Jul 30, 2017 11:46 AM
edman
Jan 22, 2015 02:45 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
