Tune a LT-1?
Old Nov 7, 2007 | 09:07 AM
DAVE00's Avatar
Tune a LT-1?
Anybody know a good LT-1 tuner program out there that I can use to make basic changes like injector size, gear ratio, etc... I am looking at the LT1edit from carputing but $200 seems steap! I have a data master cable and can connect to my PCM just fine, but was just wondering if there was other options out there. I am also looking to the future as well as the LT1 gets older it will be harder and harder to find programs to cover it. Let me know and thanks for your input.
Old Nov 7, 2007 | 09:31 AM
JAB's Avatar
JAB
Either LT1edit or Tunercat.
I have Tunercat and it seems pretty easy to use.
Old Nov 7, 2007 | 10:00 AM
JoeliusZ28's Avatar
tunercat has more function but can be a bit harder to understand. Im going to be using tunercat to tune my car in the spring.
Old Nov 7, 2007 | 11:26 AM
rickreeves1's Avatar
You can get tunercat as a trial version if you would like to evaluate it first. You just have to buy the definition file which is $20 to download.
http://www.tunercat.com/
Old Nov 7, 2007 | 11:40 AM
Rising Phoenix's Avatar
Tunercat ftw!
Don't forget a datalogging program so you can actually see what's going on. Check out TTS Datamaster..
Old Nov 7, 2007 | 02:22 PM
DAVE00's Avatar
Can't you just use the PCMREAD program (Free) to read and save a .lt1 file of your PCM and then import or open this in tunercat to modify. Looks like tunercat supports .lt1 files as well. Would this not be better if your computer is already custom programmed and you want to just modify a few parameters instead of going with a new file? Let me know.
Old Nov 7, 2007 | 02:44 PM
Stl94LT1's Avatar
With TunerCat you can make a copy of your current tune and save. Make changes to this file, rename, and reflash.
Old Nov 7, 2007 | 02:49 PM
DAVE00's Avatar
AHHHHH I see said the blind man. I wasn't sure tunercat would let you make a current copy of your PCM flash. Oh well, I'll get the definition file as it looks like this is what the program uses to define your particular parameters on your PCM.
Old Nov 7, 2007 | 06:23 PM
mrz28 73/97's Avatar
What about HP Tuners, does it workwith the LT1 cars?
Old Nov 8, 2007 | 07:31 AM
DAVE00's Avatar
Doesn't look like it as their website only supports '98 and up Fbodys and '97 and up Corvette's and this is when the LS1 started production. The last year for the LT-1 was '97 in the Fbodys. Sorry.
Wish they would cause it's a pretty sweet looking program.
Old Nov 8, 2007 | 04:47 PM
2QUIK6's Avatar
I thought I had read that Tunercat had been bought by some big tuning software company and their prices had went up and it only worked now on your specific VIN similar to LT1Edit, but continuing to support existing Customers for the def files was the same.... Has it changed or is it still basically the same product it was 3-5 years ago?
Old Nov 8, 2007 | 06:35 PM
Stl94LT1's Avatar
TunerCat still sells their OBDI software which isn't VIN specific, pretty sure they sold the OBDII stuff.
Old Nov 8, 2007 | 08:57 PM
FASTFATBOY's Avatar
Prices?
Old Nov 8, 2007 | 09:01 PM
2QUIK6's Avatar
Originally Posted by FASTFATBOY
Prices?
This page says $69.95 plus $20 for a LT1 def file. That seems to be cheaper than it was a few years ago.
http://www.tunercat.com/tnr_desc/do_tc.html
Old Nov 8, 2007 | 09:02 PM
2QUIK6's Avatar
I guess that was it, and from the link above I just found. Thx
Aug 24, 2015 06:41 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Shookiez28
Jul 23, 2015 01:55 PM
1995Blackz28
Jul 20, 2015 09:34 AM
