Priming after oil change
Old Nov 8, 2007 | 01:37 AM
blwn31's Avatar
I have searched the site and haven't found an answer to my question. Does anyone know any way to prime an LT1 oil system prior to starting after an oil change? If I pull the fuse for the fuel pump will the computer throw a code? I'm looking for an easy no hassle way to do it. My 95 spun the no.1 rod bearing with only 65k on it. My wife drove the car as her daily driver. I know it wasn't abused. The only thing I could think that caused it was semi dry starting. When I would start the car after an oil change, it would rattle the rods for a second or two. I changed the oil religously every 2k with the correct oil. Old school type PM.
Keith...
Old Nov 8, 2007 | 02:11 AM
Zachz28's Avatar
Fill the filter with oil before you start it, that will be plenty.
Old Nov 8, 2007 | 05:51 AM
1fastgixxer's Avatar
+1 that is a given on every car.
Old Nov 8, 2007 | 06:46 AM
That's not what caused your spun bearing. If it was, every car would have spun a bearing by now. If you still want to give it some cranks without it starting, pull the PCM BATT fuse. And fill the filter, as already mentioned.
Old Nov 8, 2007 | 09:56 AM
blwn31's Avatar
Yeah, I always fill the filter to the top before installation. I figured the engine must of been built incorrectly from the factory but, just wanted to make sure it doesn't happen with my replacement engine. It's a lot of work to pull an engine out of one of these cars! I have never had an SBC fail me during it's regular service life. Oh well, luck of the draw.
Keith...
Old Nov 8, 2007 | 04:43 PM
2QUIK6's Avatar
A buddy of mine threw a rod through the bottom of the pan on his '95 TA just accellerating in heavy traffic from a red light, not even trying to go above 30mph, had 80k on the clock when that happened...so its basically luck of the draw as you say, it was his wife's car and was never hammered on.
Old Nov 8, 2007 | 09:49 PM
tagz's Avatar
Alot of cars have sideways filters, making it impossible to fill. i always fill them when i can but it should not matter.
SpeedJunkee
Apr 23, 2015 09:51 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
