tune?
Old May 9, 2011 | 10:08 PM
macsz28's Avatar
tune?
I should be getting my heads back from Lloyd elliott soon and need to get my computer tuned... I have a LT1 with LE2 heads cc503 cam headers and the normal bolt-ons... who is the best around? Any and all opinions would be nice... thanks!!!
Old May 10, 2011 | 02:08 AM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: tune?
If you can get a dyno tune then that would be your best bet but if you can't then a mail order tune from pcmforless or madz28 would do the trick
Old May 10, 2011 | 01:11 PM
macsz28's Avatar
Re: tune?
id really like to get the dyno tune... only problem is... theres not 1 close to me that i am aware of... guess ill keep looking
Old May 10, 2011 | 11:57 PM
johnnyb's Avatar
Re: tune?
Where are you located? If going mail order I would suggest pcm4less with le stuff as Bryan Herter of pcm4less did Lloyd's tune (and mine )
Old May 11, 2011 | 08:24 AM
macsz28's Avatar
Re: tune?
im located in alabama... just north of birmingham... if i find someone within driving distance ill have it dyno tuned... if not ill go with pcm4less... thanks!!
Old May 11, 2011 | 10:43 AM
95TA04GOAT's Avatar
Re: tune?
Just to show the benefits of a good dyno tune, I picked up 30rwhp with a dyno tune over a mail order tune when i put my 383 H/C motor together. I took the trip from New York to North Carolina to get Carolina Auto Masters to tune it.
Old May 11, 2011 | 04:12 PM
johnnyb's Avatar
Re: tune?
I guess I didnt really specify in my post, but I got a dyno tune from pcm4less. I originally had an le3 mail order tune from madz28 while I saved up money for my dyno tune. The base run on the dyno was with madz's mail order and I picked up 15hp when Bryan put his generic le3 tune on my car. I then picked up 15hp more from tweaking it on the dyno. So the dyno tune really is your best bet like others have said.
Old May 11, 2011 | 10:24 PM
GreasyB's Avatar
Re: tune?
Had really really bad luck with madz28 tune. Would not recomend. Local tuner did wonders over the mail order tune. I would steer way clear of anything mail order.
Old May 17, 2011 | 07:55 PM
hulettsz28's Avatar
Re: tune?
Dyno would be best, but for your setup you will be fine with a mail order. Madz28 has a fantastic product
Old May 17, 2011 | 11:51 PM
doferrell's Avatar
Re: tune?
there used 2 be a dyno tune in pelham, i cant remember the name but i wanna say it was called pelham performance. they did some work 4 a friend of mine back home and he said they were very good, i dont know how much of a difference it would be but he had them tune a supercharged mustangs, i would assume they could work on others as well.
Old May 18, 2011 | 10:10 AM
Mystery Bird's Avatar
Re: tune?
I had mine tuned by Madz and was very happy. I bought the package where updates are only $25.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
