high idle while moving
finally got the idle set right
rpm ~900
TP(v) .55
TP(%) 0
iac ~50
and it idles right at or around 900 when stopped, however if i am moving at all it stays around 2k even in neutral with the clutch in or out, but as soon as i come to a stop (no change in gear, clutch or throttle) it drops right down to where it should be
any ideas would be appreciated
rpm ~900
TP(v) .55
TP(%) 0
iac ~50
The idle speed is normally elevated in the stock programming when the vehicle is moving (VSS not = 0). 2K would appear to be a bit high though. I think the elevated RPM is controlled by the "follower" table, or something like that.
my car is loud as it is and i usually try to just roll through my community to avoid annoying people any more than i already do and 2k is very loud
A higher idle when moving as previously stated is normal. Mine is in the
1200-1400 range and 2k sounds a bit high. Mine will also on occasion stay
at the high idle for 8-10 seconds after stopping, but it eventually settles
down to the normal idle.
trust me its not music at 2+k
this morning it started perfect and idled great, until i got half way to work. then it went up to like 2200.
i guess i am just going to have to back off on the throttle plate adjustment and deal with it ideling like crap when cold
dangalla, if you have a scanner, check your IAC when running. In the throttle follower table the stock setting for over 0 mph= IAC +5, 4 mph = IAC +8, 8 mph IAC + 8 and 12-64 MPH adds +12 to IAC. Your original post said IAC was at 50 during idle. so you s/b running IAC 63 when over 12 mph. For you setup not sure where 63 will get you but 2K may be high ? See what Bryan has to say..
just talked with bryan, man another +1 for pcmforlesss, so willing to help as much as he can
he said to reset the kam, back off the throttle plate a bit to get the iac around 65 at idle, and to set the TPS a little higher around .67.
gonna do that after work and see how that goes
well i set the TPS at exactly .67 and reset the kam
i left the shop and it was around 1500, an improvement. and by the time i got home ~10 miles it was down around 1200. so i guess thats about normal
thanks for all the input everyone
(the pain is worth the gain)
