trying one more time to get dash vents
Old Jan 20, 2004 | 10:56 PM
Miles-'s Avatar
I have been having an issue with my dash vents not working. Only the floor and defroster works by default. I replaced the check valve and a cracked line running from the valve to the vacuum canister. I also used a mityvac to test all three lines. (all from check valve to manifold, to canister, and to dash controls they all seemed to hold a vacuum. I am now stumped and don’t know where to look. Is there anything else I can check, getting a little frustrated and about ready to take it somewhere and pay the 70 bucks to have it diagnosed. Hope someone has some ideas.
Thanks miles
Old Jan 20, 2004 | 11:07 PM
So you can remove the vacuum line at the intake manifold, pump it up to create ~20" of vacuum and it holds?
Do you hear any hissing going on at the mode selector on the dash when you change modes? Maybe the problem is there.
Old Jan 21, 2004 | 05:28 AM
slopokrodrigez's Avatar
I second that, I had to remove the control from the dash and hook up the mityvac to each actuator's hose individually until I found mine. Do you know the color code?
Old Jan 21, 2004 | 09:06 AM
Brian 96 Z28's Avatar
Mine cracked the replacement valve in about a week, I RTV'd the original and it's still together since last summer. May want to check the valve again.
Old Jan 22, 2004 | 10:55 AM
Miles-'s Avatar
the valve is fine, I always check that first since i know its an easy fix. The line at the manifold holds. I pull it off and then stuck the vac on that end and it held fine. I dont think i hear anything when i switch the controls. I guess this would be a test when the motor is on right? I will check for this today when i run to the store. How hard is it to get into the dash to check those lines? Sounds like a pain in the a**
miles
Old Jan 22, 2004 | 06:28 PM
You only have to get to the control. From there you can test the incoming line for vacuum and apply vacuum by hand to the 4 lines to test for leaks to each individual actuator. If your control makes no vacuum noise when switching from function to function, then you have lost vacuum from the engine compartment to the controls.
That is easy to test from the controller. I think I had to remove the kick panel driver side and pull the glove box door down to get the center bezel off.
Old Jan 23, 2004 | 03:14 AM
Miles-'s Avatar
i hear a swooshing sound is the best i can describe when changing the **** quickly. I think that is normal. can you give me a detailed list of what or how to disassemble to get to that control. It would be appreciated.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
CARiD
Jan 14, 2015 04:00 AM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
