tryed starting my moto today
Old Aug 21, 2007 | 12:24 AM
lt1chevelle's Avatar
well after fixing some problems with my regulator(had the main line going to the retuen line port) i finally got fule going into the injectors(i think) but my fule peressuer gage did not read anything just kinda bounced around.the moto fired really qiut then turned off as i let go of the key. so i dont know if it becuase its not getting any fule or if the wiring is messed up on my ignition switch. she sounds mean just for that split seconed it fired need all the info you guys have wanna get her running tomarrow!!!
Old Aug 21, 2007 | 12:29 AM
JP95ZM6's Avatar
Sounds like maybe the lines are not bled yet, or you damaged the regulator when it was hooked up backwards. Did you try several key-on cycles to run the pump enough? Or, jump 12V to the gray fuel pump prime wire by the PCM to run the pump longer. You should eventually get pressure. Engine won't run without good solid fuel pressure first.
Gas in tank, right?
Old Aug 21, 2007 | 12:37 AM
ya there is gas, how many cycles should you do? i did it several times and you can hear the pump kinda lug down like it buiulding peruesser also after i turn the car over and it fires one i can hear a hissing sound can that be the injectors not seated good enough? i dunno its my first time with all this wiring and fule injection stuff.
Amshnock
14
Jan 18, 2015 11:47 AM
StngStlkr
Sep 6, 2002 05:47 PM
Head Hunter
Aug 29, 2002 07:21 AM
sleeperZ96BT
Aug 20, 2002 09:07 PM
