true duals and subframe connectors
Old Sep 14, 2003 | 02:28 PM
chevyboy_z28's Avatar
ive heard that w/ true duals youll have to sacrifice using an aftermarket t/a and subframe connectors, but in a recent thread i read that as long as you use a torque arm w/ stock mounting location itll work. i also heard that some subframe connectors wont work (i.e kenny brown d.d.), but regular ones will (i.e. hotchkis). but will the regular (straight) connectors work well enough?
Old Sep 14, 2003 | 03:01 PM
Gripenfelter's Avatar
Depends on how you do the true duals.
I have Double Diamond SFCs from www.sybersport.com and they fit great. About $189 shipped to your door.
Email Darren and tell him Grip sent you when you're ready to buy. info@sybersport.com
For the torque arm you can't use Spohn but you can use BMR adjustables.
Old Sep 15, 2003 | 12:10 AM
revtime's Avatar
I have Double Diamond subframes and a BMR TA.
Biggest problem I have is the tranny crossmember not the SFCs or the TA.
Old Sep 15, 2003 | 02:10 AM
Caged Monkey's Avatar
The only problem I have had with mine is the drivers side tranny x-member but the exhaust guy did a great job of going under it. The SFC's were not even a issue and I have KB DD's.
RUENUF
Mar 13, 2016 03:37 PM
generaldave
Sep 25, 2015 06:48 PM
Henson071
Sep 18, 2015 04:01 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
