True duals with SFC
Old Mar 2, 2003 | 05:47 PM
Chuck2's Avatar
True duals with SFC
Is this possible to have both true duals and subframe connectors? Not sure exactly of the positioning of the subframe connectors so i nend ot know weather there is room above or below the SFCs once installed. Thanks
Old Mar 2, 2003 | 08:39 PM
Chuck2's Avatar
come on somebody on here has to know or even someone with subframe connectors can speculate weather there is room for true duals or not.
Old Mar 2, 2003 | 08:55 PM
Z28Nut's Avatar
I haven't installed my SFCs yet but they are Competition Engineering brand and they mount a few inches inside of the rocker panels. They set pretty tight up to the floor pan but I don't think they would interfere with true duals running on either side of the driveshaft tunnel.
I'm kicking around if I want to run true duals when I put in headers this spring. Problem is ground clearance with the end of my driveway.
Good luck!
Old Mar 2, 2003 | 09:00 PM
NOMAD's Avatar
Cool
True duals will fit as long as you don't have SFC's that tie into the middle. Regular SFC's just run down the side of the car, attaching the front of the sub frame to the rear
-Shannon
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
