True duals with SFC
True duals with SFC
Is this possible to have both true duals and subframe connectors? Not sure exactly of the positioning of the subframe connectors so i nend ot know weather there is room above or below the SFCs once installed. Thanks
I haven't installed my SFCs yet but they are Competition Engineering brand and they mount a few inches inside of the rocker panels. They set pretty tight up to the floor pan but I don't think they would interfere with true duals running on either side of the driveshaft tunnel.
I'm kicking around if I want to run true duals when I put in headers this spring. Problem is ground clearance with the end of my driveway.
Good luck!
Good luck!
RX Speed Works
Oct 1, 2015 10:19 PM
