True duals HELP...
Old Apr 7, 2005 | 10:23 PM
jaredwayt's Avatar
True duals HELP...
i need some help, my friend is selling these true duals off his car(description below) and i was wondering if they would fit, or what i would have to do to make them fit on a stock lt1 with stock exhaust manifolds.i would need o2 sims correct?how would they be mounted?
True duals for F-body.. Dr. Gas 3" X and one chamber Flowmaster Delta Force race mufflers They have a 3 bolt flange on the end and Ill give you the slip on coupling that will fit SLPs or Kooks. Its a 3" ID to a 3" OD with a 3 bolt flange welded on so you dont have to weld one on the headers
Old Apr 7, 2005 | 10:31 PM
bdc95ta's Avatar
Re: True duals HELP...
you would need to take it to an compident exhaust shop and have them fab up the extra pipe you need to connect to your manifolds. But 3" is to much for stock manifolds. Remember the closer you are to the engine the more crucial the exhaust becomes.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
