True duals
Old Jun 14, 2006 | 06:08 PM
quick98's Avatar
True duals
Is there a difference between LT1 TD's and LS1 TD's?? I want to get True duals for my 97 to go along with Pacesetter long tubes. I didn't know if there was a difference in where they bolt up to the headers or not.
Old Jun 14, 2006 | 07:07 PM
tyrsmkr's Avatar
Re: True duals
Yeah they are different. I think the driver side on the LS1 dual has a kink in it that the lt1's don't. Don't quote me on anything here, but I know they are different.
Old Jun 14, 2006 | 08:09 PM
396D1SS's Avatar
Re: True duals
They are different the ls1's left collector flange has a slight curve to it
Old Jun 14, 2006 | 08:29 PM
quick98's Avatar
Re: True duals
Where are some good places to get LT1 TD's then?? I'm new to the LT1 world and don't know that many places then. All the ones that I look on the regular sites say 98-02 even when you click on LT1 exhaust.
Old Jun 14, 2006 | 08:40 PM
396D1SS's Avatar
Re: True duals
I got flowmaster 2 chamber 40 series from summit and went to a local exhaust shop fabbed up my true duals with an h pipe and dumps before the rear axle for 200 bucks
Old Jun 14, 2006 | 08:48 PM
tyrsmkr's Avatar
Re: True duals
Call Texas-speed. They have a true dual kit in the works, and ive actually heard you can buy em right now. Its not listed on the site, so just call.
Old Jun 20, 2006 | 11:19 PM
mebanditws6's Avatar
Re: True duals
Buy the Summit or Jegs universal kit with an X pipe, your choice of mufflers (Bullets or Spiral flows would be best for space and sound), and have a muffler shop tweak it to fit your headers. Also, get some band clamps to use on the header collectors. They seal great and make it a snap to remove the system should you ever need to.
Jason
Old Jun 20, 2006 | 11:50 PM
quick98's Avatar
Re: True duals
Jason
That's kind of what I've been leaning towards. I know a couple good fab guys so it shouldn't cost me all that much.
Old Jun 21, 2006 | 10:16 AM
1BadBrd's Avatar
Re: True duals
hope ground clearence isn't an issue
Old Jun 22, 2006 | 08:44 AM
Re: True duals
Ground clearance is barely affected if the guy doing the work knows what he's doing, even on a 3" setup.
Jason
Old Jun 22, 2006 | 10:43 AM
speed_demon24's Avatar
Re: True duals
I have 3" true duals run out the back under the axle and ground clearance is fine, I haven't bottomed out the exhaust once.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
