Trucks almost done... Need some HP and track time estimates....
Old Jun 6, 2004 | 03:25 AM
Eric85's Avatar
Ok guys the motor swap is almost done and should be started by next friday if my block gets here in time. Now here is a list of my mods if i can remember them all. I want to know what you guys think it will hit at the rear wheels and what it can run.
4 bolt main Lt1
233/239 cam
1.6 magnum roller rockers
Comp valvetrain including 987 springs and titanium retainers
Port and polished heads to match Cam with 2.02/1.6 valves
Ported intake
Sanderson 1 5/8 primary shorties
full 3 inch exhaust with Dynomax Hemi turbo mufflers
3.73 gears
Eaton posi
3000 Midwest stall
walbro intank pump
bosch 30 lb injectors
Cloyes true double roller
Meizere Electric water pump
Truck will be run with drag radials. What do you guys think. Im hoping for 400 at the wheels and hopefully if i can get a decent 60 foot time i want to run a low low 12.
Old Jun 6, 2004 | 04:56 AM
97WS6SCharged's Avatar
What motor mounts did you end up using with those Sanderson headers?
Old Jun 6, 2004 | 05:44 AM
Eric85's Avatar
i am using the 2.8 frame mounts and the Jags that run Motor mounts.
Old Jun 6, 2004 | 10:37 AM
Eric85's Avatar
bump
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
GRN96WS6
Sep 8, 2002 10:45 PM
teedoff59
Aug 8, 2002 01:36 AM
