Trouble Starting since using Seafoam Deep Creep
Old Feb 14, 2010 | 10:35 PM
  #16
Fatdog2's Avatar
Might get some throttle body approved carb cleaner and spray ever so gently into the mas and see if that helps.(Do the cheap stuff first).Coil wire?Hope this helps.
Old Feb 15, 2010 | 05:10 AM
  #17
bw_hunter's Avatar
Is it possible that, during cleaning, some of the crud carrying solvent made it into the solenoi portion of the IAC? If you suspect that could be the case, remoe the TB, the IAC from it and, holding it pintle down, spray the living blank out of it being certain to get up into the body as much as possible.
Just a thought....
Old Feb 16, 2010 | 11:52 PM
  #18
omgwtfdied's Avatar
IAC valve
Old Feb 17, 2010 | 09:40 AM
  #19
wrd1972's Avatar
FWIW, when I used to seafoam the camaro, I used the smaller opti hose as opposed to the bigger brake booster hose. The smaller dosage would seem to cause the least amount "problems".
Awesome user name "omgwtfdied"
Old Feb 18, 2010 | 01:47 AM
  #20
omgwtfdied's Avatar
haha thanks man
armedtrigger
Feb 24, 2015 08:30 PM
NewsBot
Feb 6, 2015 05:00 PM
edman
Jan 25, 2015 02:41 PM
David Dorris
Jan 17, 2015 08:10 PM
slothgrant
Aug 22, 2002 03:01 PM
