trouble code
Old Jan 30, 2006 | 03:51 PM
95TAMaddog's Avatar
Question trouble code
I am getting a trouble code in my 95 ta. It is malf 48: malf system failed. I was wondering if this was my O2 sensor or some thing to do with my opti. Any help would be appreciated. Thanks
Old Jan 30, 2006 | 04:22 PM
Re: trouble code
Mass Air Flow (MAF) sensor circuit
That's what DTC 48 is for and what you need to check.
Old Jan 30, 2006 | 04:48 PM
95TAMaddog's Avatar
Re: trouble code
What do I need to check?
Old Jan 30, 2006 | 05:07 PM
Deenasty's Avatar
Re: trouble code
Its the MAF. Mass Airflow Sensor. It is located on the intake coming off of the TB. Its a big Silver round thing.
Old Jan 30, 2006 | 05:11 PM
95TAMaddog's Avatar
Re: trouble code
would it change anything that I have a vortec supercharger on it
Old Jan 30, 2006 | 05:17 PM
Re: trouble code
It really helps when you tell about your car, transmission, mods and any other pertinent info. You can't expect educated help without it. Most people put these things in a signature.
Start by making sure the MAF has power on the pink wire (key ON). We also don't know if your code is constant or intermittent.
Old Jan 30, 2006 | 05:22 PM
Deenasty's Avatar
Re: trouble code
yea we need to know about the car. Does it run? Does it start? Is the code always on?
Old Jan 30, 2006 | 05:41 PM
95TAMaddog's Avatar
Re: trouble code
It does start. This just started yesterday. The car runs. The only thing it did was cut out a couple of times. Yes the light stays on. Car has a vortec supercharger, 6 psi boost 42# injectors and mail order tune. The rest of the car is stock with 6 speed
Old Jan 30, 2006 | 06:20 PM
Deenasty's Avatar
Re: trouble code
You might want to clean the electrodes on the MAF with some rubbing alcohol and a q-tip. BE VERY CAREFUL NOT TO DAMAGE THEM. If not, a replacement is going to need to be purchased..
Old Jan 30, 2006 | 07:04 PM
95TAMaddog's Avatar
Re: trouble code
thanks
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
