Trouble with AFR heads/valve cover sealing
Old Sep 13, 2004 | 09:25 AM
BlownF1's Avatar
Got the motor running and seem to have what we suspect is oil up near the top of the motor towards the rear outside of the passenger side head. I don't believe it's an intake leak, but will confirm.
One thing to note is that the heads are AFR's and when we installed the valve covers, the corners interfered. The rim that the gasket sits on is wider in some areas than the rest, so we ended up bending the edges out slightly. I suspect this is the problem, and if so, what can we do? Probably should of had the extra material removed from the heads, too late to do easily now...
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
