Trimming Header Gaskets
Old Feb 27, 2005 | 08:36 PM
Munson's Avatar
Hey, the car is going in the shop tommorow morning for the heads/ cam install.. I have jet hot long tubes with the O ports on them so i got some O port EARLS header gaskets... On the tops of the d ports on the heads where it is curved the gaskets are a little too small... I started to trim the gaskets a little bit then i got to thinking that it might just burn out. Any suggestions?
Old Feb 27, 2005 | 08:39 PM
Heatmaker's Avatar
Advanced Member
Re: Trimming Header Gaskets
Why do your headers have LS-1 ports?
Old Feb 27, 2005 | 08:42 PM
Munson's Avatar
i dunno apparently thats how jet hot did alot of their lt1 long tubes... any suggestions on the gasket situation?
Old Feb 27, 2005 | 10:48 PM
Brent94Z's Avatar
Super Moderator
How much will you need to trim them? I had to trim mine a little but not to the point I thought I'd have problems. If it looks like you will need to trim them too much, might want to get a set of "regular" header gaskets and trim those as needed instead. I like the Mr Gasket ones. Even have a picture trimming them
http://www.brentfranker.com/gallery/...1/131_3165_IMG
http://www.brentfranker.com/gallery/...1/131_3167_IMG
Midnight_Z
Feb 16, 2016 09:36 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
