tried searching, what lifters to use?
Old Feb 16, 2006 | 11:13 AM
firebirdStud's Avatar
Lightbulb tried searching, what lifters to use?
I have been playing with the seach function for about a half hour and not finding what I want to know.
So, which lifters would be the best for a stroker, using comp pro mags 1.6 roller rockers, probably comp 918 beehives? I will be doing NSA rockers, with guideplates of course, and this is a daily driver. I want good peices, not clicky cheap ones, but I don't want to blow 500 dollars on them. I am not interested in the comp R's as everyone has problems with them failing. I am running jegs replacement stockers now, but I don't think the spring pressures will equal the beehives.. am I wrong? Anyway, this motor is gonna be new, so I want new lifters too. So, let the suggestions begin!
Old Feb 16, 2006 | 01:48 PM
SStrokerAce's Avatar
Re: tried searching, what lifters to use?
Stock lifters are fine, but the best stuff out there is the Morel's.
Bret
Old Feb 16, 2006 | 02:41 PM
rskrause's Avatar
Moderator
What the man said! Nothing wrong with the stockers unless you are running high spring pressure/high rpm. In which case the Morel's are the best bet. Why not just get 'em? They are around $500.
Rich
Old Feb 16, 2006 | 08:47 PM
hmm, so stockers would be fine for the beehives? Then Im sold! Under 200 for GM or 500 for "not needed." Ill go GM. thanks a ton guys!
Old Feb 17, 2006 | 06:22 PM
amean94ta's Avatar
Bret
anyone trying those sheubeck roller x's i just read about them no needle bearings to blow out
Old Feb 17, 2006 | 07:25 PM
Jameslt1TA's Avatar
Im running stockers, seems to work out good.
Old Feb 17, 2006 | 08:44 PM
amean94ta's Avatar
I found the morel's for $399 for solid roller version but i think i am letting bret get them for me
Old Feb 17, 2006 | 08:50 PM
rskrause's Avatar
Moderator
The HR is more expensive.
Rich
Old Feb 17, 2006 | 09:09 PM
Cmr0z28's Avatar
I'm running my stock 98,000 mile lifters without any problems (Beehives, XE 224/230)
Old Feb 17, 2006 | 09:44 PM
interesting. I was thinkin about just the comp replacements, or maybe the cranes. Anyone try just the stock replacements from them too, or just do GM?
Old Feb 18, 2006 | 08:27 AM
96capricemgr's Avatar
Beehives big advantage is lesser spring pressure for the same valvetrain control, so they can control a fairly wild cam without all sorts of other valvetrain work you would normally have to consider with other springs.
Old Feb 18, 2006 | 11:43 AM
97WS6SCharged's Avatar
Using a set of solid comp roller lifters (don't remember which though ) in my new motor with a slightly taller body to offset the smaller base circle camshaft in it.
Old Feb 18, 2006 | 02:36 PM
so no one has the cranes, or comps replacements? Only GMs for everyone else?
Old Feb 18, 2006 | 04:23 PM
Wckd94Z's Avatar
i'm using my stock 78k mile lifters with my 918s and CC306. I have a set of old Comp Rs that i'll use when i put a bigger cam in, just to avoid float.
Old Feb 18, 2006 | 04:29 PM
amean94ta's Avatar
fawk comp r's worst lifter ever made!!!!!!!!!
crane/oem for good price but after that you spend some money
