Trickflow or Vortech
Old May 25, 2004 | 10:26 PM
HunterLT1's Avatar
I need to replace my intake elbow, and i'm looking at either the polished vortech or the trickflow available at summit, can anyone post experiences with either? Also, will that sensor that plugs into the elbow plug into either of these like stock?
http://store.summitracing.com/productdetail.asp?p=5319
http://store.summitracing.com/partde...2D4GH112%2D058
Old May 25, 2004 | 10:47 PM
ScrmngChckn95's Avatar
both come with all sensor fittings, but i've heard the vortec doesn't work with throttle body air foils because of the divider. If you're just wanting to get rid of the intake silencer you can also go with a 1le intake elbow from gm parts direct or a intake elbow plug.
plug is at: http://www.thunderracing.com/catalog...vid=4&pcid=219
Old May 25, 2004 | 10:50 PM
Loadre's Avatar
Do a search.
But get the Trick Flow.
Old May 25, 2004 | 10:51 PM
HunterLT1's Avatar
ah, didn't notice that divider, looks like trick flow it is, thanks.
Old May 25, 2004 | 10:56 PM
formula383's Avatar
Definitely go with the Trick Flow, it looks good and from what I heard you have to cut the Vortech elbow to get it to work. But, you don't the Trick Flow.
Old May 25, 2004 | 11:14 PM
MarkyMark's Avatar
Go
my trick flow is the ****......highly reccomend it. It looks 10 times better than the stock elbow also.
________
Magic Flight Launch Box
Old May 25, 2004 | 11:19 PM
25thBird's Avatar
I have the polished Vortech elbow, and it looks awsome. It did interfere with my Holley air foil, but i was able to modify the foil to make it work. It was no biggie to modify and was worth the time. I didn't have any problems istalling it, other than air foil part.
Old May 31, 2004 | 09:32 PM
Myxtreme1's Avatar
Does the air foild really help?
Old Jun 1, 2004 | 06:33 AM
NVetro's Avatar
Get the trick flow, I have the vortech and hate that middle divider. It messes with my n2o system with the shark nozzle.
Old Jun 1, 2004 | 06:48 AM
IDOXLR8's Avatar
I also have the trick flow and the install was extremely easy.
Old Jun 1, 2004 | 07:42 PM
25thBird's Avatar
I guess it really depends on the car... I felt a difference as soon as I started driving it, considering one of my spark wires was being cut by one of the pulleys and I had a slight misfire.
Old Jun 1, 2004 | 07:53 PM
Eliminator's Avatar
Another vote for Trick Flow.
Old Jun 2, 2004 | 05:05 PM
Derrick Redd's Avatar
My vote goes for the Trickflow also.
Old Jun 2, 2004 | 05:12 PM
GreenDemon's Avatar
Trickflow.
BTW, if you have a vented opti, drill the hole somewhere else in the intake. I'm still kicking myself for drilling through the elbow when there was plenty of plastic around to use.
Old Jun 2, 2004 | 08:29 PM
Somnambulist's Avatar
The air foil does next to nothing. You May see ~1hp increase with tons of other stuff done...
SOTP feeling? That's a negative ghost rider...
13qtr
Oct 28, 2016 08:11 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
