TrickFlow Heads for LT1?
Old Feb 26, 2004 | 05:57 PM
CamZ2811's Avatar
I have home ported lt1’s and they flow just under 280cfm w/ the cam that I had. now i have (comp 242/248@.05) that’s just not going to be enough air. So I’m going aftermarket. Ive been trying to figure out which heads to get. I have seen the afr's and some others. but cant find pricing for the afr's. from what ive been told there pricy dose anyone know how much they are? I just need the basic stage1 lt1 or lt4 set they will be home ported.
The others I looked at are the T/F. dose anyone know how much room they have for additional porting and what they flow out of the box? I cant seem to find any flow numbers for them.
Any other recomendations would be good!
Thanx
-brian
Old Feb 26, 2004 | 06:19 PM
SVT Killer LV's Avatar
TFS's have always been know for being able to flow killer numbers, these are essentially their SBC head with revised coolant passages, the SBC heads have easily seen over 300cfm at .600 with a decent port job. big ports are in the 320+range....
Old Feb 26, 2004 | 06:33 PM
CamZ2811's Avatar
thanx dude!
I woud like to know more about both if anyone has more info that would be grand
TTT for me!
-brian
Old Feb 26, 2004 | 07:32 PM
CamZ2811's Avatar
ttt
Old Feb 26, 2004 | 07:45 PM
96ZUL8TR's Avatar
i have a set of the t/f heads, they are identical to their 23* regular sbc heads, the flow for them are 253/.500 and 254/.600. there is lots of room for porting them, mine are flowing 306/.600 after some minor clean up around the bowls. if you are using stock pistons your compression will drop considerably since the heads have 62cc chambers.
Van's Avatar
Van
Do you port heads for a living?
280~ is an impressive number for LT1 castings. What lift was your peak at?
What were your exhaust #'s at similar lift?
Van
Old Feb 26, 2004 | 10:51 PM
CamZ2811's Avatar
no i dont port for a living my friend ports heads out of his house in his spare time for close friends..... OOPS! sorry i will edit that one!
they flow 280cfm@.525
-brian
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
