trick to launching w/converter?
Old Sep 24, 2003 | 11:04 PM
  #16
GrdLockV6's Avatar
Originally posted by WheelmanZ28
Line Lock is for burnouts
Trans Brake is for launches
Exactly. What will a line lock do that holding down the damn brake pedal won't?! Line lock is a waste of money if all you need is help on launches. Line locks are for burnouts.
Old Sep 24, 2003 | 11:09 PM
  #17
wayne97's Avatar
WITH THAT SAID....
I'm pretty sure that everyone agrees on at least one thing...
Im not gonna hook up well no matter how I launch this thing, so I will probably buy a set of DR's off a local guy. HOWEVER I have 107k on my stock rear ... Is this a recipe for disaster? Am I going to tow my car home on Saturday night??
Old Sep 24, 2003 | 11:47 PM
  #18
revtime's Avatar
A4s are not nearly as hard on rears as the 6 speeds are.
I can,t guarantee you won,t break it but its not likely.
I have been running my stock 10 bolt with 3.73s for over 5 years now with no problems.
I have not bettered my 2.0 sixty foot yet though.
Old Sep 24, 2003 | 11:55 PM
  #19
BES-383's Avatar
I used my stock rearend with 373s TA cover and welded tubes. Pulled 1.70s 60" times for 2 years and never harmed the rearend. this was using M/T ET STREETS. I went through 2 sets of these slicks.
Would even pull the left front tire off the ground. As long as you have an a4 your rearend will live.
Old Sep 25, 2003 | 02:23 AM
  #20
96redformula7's Avatar
I have the same problem
a4 , 3.73's, PI 2800 Stall
I am ordering some new goodyear f1 gs-d3's(number 1 rated tire on tirerack.com) hoping that I will be able to plant better than I do with my ****ty as POS yokomama all season tires.
Old Sep 25, 2003 | 03:41 AM
  #21
AndyB's Avatar
If I know I am only going to be running street tires on the car I wont change the gears. Hooking up with stock gears and a TC is easier than hooking up with gears and a TC.
I've learned gears are kind of worthless if ya can't hook up
Old Sep 25, 2003 | 07:57 AM
  #22
TonyJ's Avatar
Besides the transbrake, you can also use a two-step to launch. It will hold your RPMs to an exact point until you are ready and then off you go. They can really help you get repeatable 60s...
walt355
Mar 16, 2016 09:35 AM
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
alphaauto
Jul 26, 2015 04:40 PM
