Trick for getting oil pan back on???
Old Nov 29, 2004 | 10:39 PM
BTM's Avatar
BTM
Question Trick for getting oil pan back on???
My oil pan wasn't so hard to remove, but the stupid baffle above the main reservoir area seems to be interfering with the oil pump pickup and doesn't want to go back on...
Any tricks??
Anybody had this problem?
Old Nov 30, 2004 | 06:49 AM
93ZM6Tally's Avatar
Re: Trick for getting oil pan back on???
Take off the motor mounts and jack the engine up, it will go in easy. BTW you're not forgetting to take off the low oil level sensor are you, because that will get in the way when you're trying to put the pan back on.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
