Trick Flow intake elbow....any good?
Old Feb 21, 2004 | 01:07 PM
Jay-Roll's Avatar
Apon removing my intake elbow today to access a plug and wire change I noticed quite a bit of dirt and grime in the throttle body. I inspected the elbow and found that the bottom part of it got folded under and ripped. So I need a new one. Just wondering if anyone has had good success from TF's intake elbow. I planned on getting the ceramic coated one from Summit for $90 bux. If anyone knows where I can get one cheaper, or knows of a better one let me know.
Old Feb 21, 2004 | 01:34 PM
Don't Look Back's Avatar
I have the same one you're looking to buy. Its not a real performance upgrade, I just figured I'd replace my ripped one with one that will not tear. In my opinion, its better than the Vortech elbow, because there's no divider in the Trick Flow. I like it, I'd recommend it to anyone looking to replace an old, worn out one. I wouldn't recommend it to someone looking for performance gains.
Old Feb 21, 2004 | 01:38 PM
LilJayV10's Avatar
Exactly what he said, my friend put one on his 95Z just for the looks. If you have a vented opti you will have to drill a small hole in the side of it so you can put your vent tube in there, and the drill but that they said was supposed to work, wasn't big enough if I recall correctly. I got a bit that looked close and went with it.
Old Feb 21, 2004 | 01:41 PM
ledfootz28's Avatar
im happy with my trickflow elbow except i still had to saw off an inch on the elbow to fit my stock maf and slp cai
Old Feb 21, 2004 | 02:03 PM
Jay-Roll's Avatar
I have a K&N CAI and stock MAF. Do you think I'll have to cut anything? Also I wasn't really looking for performance gains. I just need to replace mine and I figure a flashy aftermarket replacement would look nice. Thanks for the info guys. Any place you know of to get it cheaper than Summit?
Old Feb 21, 2004 | 02:05 PM
LilJayV10's Avatar
We didn't have to modify anything, it was a direct bolt in, so to speak, the car had a K&N FIPK on it, I don't know if the SLP is different or not.
Old Feb 21, 2004 | 02:06 PM
Nope. I have the stock MAF and K&N. You'll need to cut a little off of the rubber sleeves they give you. But nothing off of the actual elbow. I don't know anywhere much cheaper than Summit.
Old Feb 21, 2004 | 03:11 PM
AxeGrinder30thZ's Avatar
I have the stock MAF and K&N and didn't have to cut anything.
I did it for looks, not performance. You won't see any gains out of it, but man, it looks sharp under the hood.
Old Feb 21, 2004 | 03:22 PM
onyxblackz28's Avatar
The elbow or the CAI has to be cut if you have a SLP CAI.(I recomend cutting the CAI, as the elbow is a lot thicker.) Other than that the only thing I can complain about is the supplied clamps. If you do any work that requires moving the elbow the clamps will strip. You may want to "invest" in other clamps I got some from Home Depot that were like 1.79 and worked 10x better than the ones Trick Flow sent.
Old Feb 21, 2004 | 03:37 PM
stangitr's Avatar
I have it and it looks great
Old Feb 21, 2004 | 04:37 PM
Eliminator's Avatar
I never knew that untill after I bought mine I was like damn cut 1 inch off and good to go, looks good.
PS: The clamps SUCK!!!!!
Old Feb 21, 2004 | 08:02 PM
Derrick Redd's Avatar
I'm happy with mine. I have a K&N CAI and Granatelli MAF, and the Trickflow elbow fit perfect.
Old Feb 21, 2004 | 08:07 PM
GreenDemon's Avatar
I've got the trick flow elbow and moroso cai, had to cut a little over an inch off the moroso to make everything fit right.
Other than that the elbow is great, no more worries about cracks, rips, etc. Now I worry about scratching it...
marineengineer
Feb 9, 2015 03:59 AM
MadMav
Feb 6, 2015 11:02 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
