Trick flow elbow for lt1?
Old Apr 25, 2011 | 12:52 AM
z28bigboy's Avatar
Do the trick flows make a difference at all compared to the stock one or is it a waist of money?
Old Apr 25, 2011 | 05:22 AM
bw_hunter's Avatar
Re: Trick flow elbow for lt1?
It looks nice so if that's important then it's not a waste of money. From a performance standpoint, I don't see how it could be worth anything....
Old Apr 25, 2011 | 12:17 PM
calaban's Avatar
I picked up a cast aluminum one; but only did it because my stock rubber elbow had a rip in it. It does look nice though and removed the piece that sticks out the bottom. It has to flow better than stock as well, but still more than likely a dress up item unless you are making an enormous amount of power.
Old Apr 25, 2011 | 01:45 PM
Shivo's Avatar
it's more so for those with the EGR deleted. It removes that big hole behind the MAF and cleans up the mess of stock rubber elbows falling apart/tearing. if you have that long tube extending down from the bottom of the elbow, then it's not for you.
Old Apr 25, 2011 | 01:47 PM
RamAir95TA's Avatar
The EGR has nothing to do with the intake ducting at all...
Old Apr 25, 2011 | 01:50 PM
Shivo's Avatar
well then excuse my ignorance and belay my last.
Old Apr 26, 2011 | 01:35 AM
speed_demon24's Avatar
The trickflow elbow is a decent amount smaller than the stocker so it's a downgrade performance wise.
Old Apr 26, 2011 | 11:14 AM
johnnyb's Avatar
huh? smaller? how so?
Old Apr 26, 2011 | 05:26 PM
slowride94z's Avatar
it is smaller than my stocker was .. some airfoils wont work
inside
Old Apr 27, 2011 | 12:18 AM
SROACH's Avatar
I had a Trickflow elbow but went to the Vortech brand. More bling.
Old Apr 27, 2011 | 05:38 AM
bw_hunter's Avatar
Any metal elbow can heat up, increasing the incoming air temp and lower performance....stick to rubber.
Old Apr 27, 2011 | 09:54 AM
calaban's Avatar
The loss of power through the heat soak of the elbow is negligable. It's going to get more heat as it goes through the TB, intake, and heads. I've never had my cast aluminum elbow hot to the touch unless the car has been sitting, idling for a few minutes. If I drove it down the road, got it good and hot, and came home and, while still running, checked it; the elbow would be cool to the touch.
Old Apr 27, 2011 | 10:30 AM
bw_hunter's Avatar
Sorry, I disagree. It's been discussed many times and the effects are real and measurable. A simple TB coolant bypass removes an additional source of intake air heating....
Old Apr 27, 2011 | 10:36 AM
calaban's Avatar
Measurable and negligable are two different things is all I'm saying. If you're talking 5 HP loss it is not negligable, if you're talking fractions of a HP then I'd say that is negligible.
Same thing with an air foil, there is measurable improvement, but unless you are makeing tons and tons of horse power it's negligible.
Old Apr 27, 2011 | 03:40 PM
That's because the heat is being absorbed by the air moving through it, keeping it nice and cool.
