trick flow elbow + airfoil = no go
Old Mar 8, 2005 | 04:06 PM
IXLR894Z28's Avatar
I recently got the Trick flow elbow and a Jet hot airfoil, problem is the airfoil will work with the stock elbow but not the Trick flow, any suggestions. By the way, the airfoil is too big for the mouth of the elbow.
Old Mar 8, 2005 | 04:09 PM
chevyguy3's Avatar
Re: trick flow elbow + airfoil = no go
you can easily grind the elbow to fit, or just clamp it down with a little space between the elbow and the throttle body (thats what i did with my vortech elbow to clear the airfoil on that engine)
Old Mar 8, 2005 | 04:36 PM
Flyin_Z28's Avatar
I would also grind down the airfoil.
I used to run the Holley airfoil but once I got the Trickflow elbow theres no way of using it. Sticks out like 1.5" from the thottle body and contacts the elbow edge.
Formula Steve
Sep 19, 2023 08:31 AM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
colts0455
Jul 24, 2015 04:51 PM
