Transmission swap clutch problem
Old Sep 9, 2003 | 01:59 AM
incarnus's Avatar
I've just finished installing a T56 in place of my 4L60E.
The master cylinder that came with the kit was cracked, so I posted on the board here and was able to get a used one from another member. Unfortunately, somewhere along the line the little rubber seal that goes on the end of the hose got lost. So I used some teflon tape on the end of the hose, and it seems to have sealed pretty well.
So I go to start the car in neutral, and everything's fine. Then I try to put it in gear, and it won't go at all, into any gear. I could feel pressure in the clutch pedal, but after about five minutes, it went away. I checked the master cylinder reservoir, and it was empty.
So my question is this: Is it likely that the only reason I can't go into gear is becasue the clutch won't disengage due to lack of line pressure in the clutch line? Or did I set up the clutch incorrectly? (It's the first one I've done.)
FYI I used the clutch that came with the swap "kit" becasue it's been like two years since I've driven a stick and I don't want to screw up a new clutch relearning how to drive.
Also, I can engage every gear smoothly when the engine is off.
Please someone help! It's been nine days sine I started this project and I really want to drive my car again!
Thanks,
Chris
Old Sep 9, 2003 | 02:04 AM
Compstall's Avatar
You've probably got air into the system. Try filling it up completely and bleeding the air out.
Old Sep 9, 2003 | 10:03 PM
incarnus's Avatar
I'll try that. If it's still no good, what should I do next?
My friends seem to think it's the lack of the rubber seal on the master, and I suspect that might be the case. I just hope I don't have to buy a new master cylinder just to get that one little part.
Old Sep 11, 2003 | 12:38 AM
Compstall's Avatar
I haven't had to buy anything for my master cylinder yet, so I'm not sure if you'll have to buy a complete assembly. I'm pretty confident you've got air in the system though.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
HectorM52
Jan 30, 2015 11:08 PM
rocketman051894
Jan 30, 2015 03:23 PM
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 12, 2014 10:51 PM
