Transmission Leak
Well this morning I went out to get something out of th ta (95 A4) when I noticed a small amount of fluid underneath the car ,looks to be tranny fluid . I havent found the location from which its coming from but seems to be toward the passengerside of the car. Im gonna be taking a look at it tonight ,but was wondering if there is any common areas I should look at and check while Im underthere. Any advice is greatily appretiated.
Gary
95Ta
Gary
95Ta
Check the transmission vent.....that is where my 95 T/A leaked occasionally from before its rebuild.
I do not think its anything to worry about if that is where its coming from.
Also check the linkage area, that seems to be common as well.
Hope that helps!
Hope that helps!
Magenta_Hearts
Mar 29, 2017 08:54 PM
