Transmission Cooler Lines
Old Jul 3, 2003 | 08:22 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i bought two cans of this "trans flush" from trans-go ( a company i recommend) to clean out all the burnt fluid/buildup in my lines and radiator from my old tranny. it says i HAVE to hook it up to the RETURN (going from radiator to transmission) line, i rolled over... (on the crawler ) and saw that the two lines split... one goes from the tranny to the TOP of the radiator, and one goes from the tranny straight into the bottom of the radiator...?
the one on the bottom of the radiator, is the return line.... right?
also, i STILL can't get my dipstick tube out of my tranny...
any help there?
THANKS!
Old Jul 3, 2003 | 09:29 AM
ChevyCamZ28's Avatar
The line on top of the radiator is the return line.
To get the dipstick out you need to remove the very top right mounting bolt of the transmission to the block. The dipstick has a tab that is sandwiched between this bolt and the transmission case. You should see it if you look up there.
Mike
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
thenewkid
Apr 12, 2015 07:42 PM
jackpawt883
Feb 26, 2015 09:04 PM
thenewkid
Nov 27, 2014 09:41 AM
