Transmission
Old May 6, 2009 | 10:45 PM
steven92f's Avatar
Transmission
Ok . So I have a96 z28 camaro with a 4 speed auto tranny. I really
Want to convert it to a manual. I have information on how to do it but curious on what transmissions I can use. Is it possible to put a 6 speed tranny in mine from a 95 v6 camaro . Or would my rear end need to be regearsd along with rewiring?
Old May 6, 2009 | 10:49 PM
hey01's Avatar
you won't need to regear anything but it def isn't the same gear ratio the 6 speeds have in the back.
why are you wanting to convert?
Old May 6, 2009 | 10:54 PM
Don't the V6s have 5 speeds? You wouldn't want to do that.
Old May 6, 2009 | 10:59 PM
6SpdLT1Z's Avatar
This is the parts list my mechanic/buddy gave me when I inquired to do it on my '94 Z28 a few years back.
-Transmission with torque arm mount shell (LT1 only, LS1 won't work)
-Bellhousing with slave cylinder adapter (LT1 only, LS1 won't work)
-Clutch, Pressure plate, throwout bearing and pilot bearing (I suggest a Spec stage 2 or 3)
-Flywheel
-Flywheel bolts and pressure plate bolts
-MM6 crossmember
-Clutch slave cylinder and master cylinder with resevior
-Pedal assembly
-Lower shifter boot (mounts to the floor)
-Upper console shifter boot and plate
-Shifter with stalk and handle
-New connector for the vehicle speed sensor
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
