transmission??
Old Nov 16, 2004 | 01:33 PM
besz28's Avatar
transmission??
dumb question but i don't know. how do i add transmission fluid to the car? thanks
Old Nov 16, 2004 | 01:55 PM
breakmyfootoff's Avatar
Re: transmission??
use a funnel with a small tip and pour it right down the dipstick tube, they make funnels specifically for this.
Old Nov 17, 2004 | 05:28 PM
besz28's Avatar
Re: transmission??
don't you add transmission fluid from the bottom on an lt1?
Old Nov 17, 2004 | 05:43 PM
blown94's Avatar
Re: transmission??
Um,.....no
Old Nov 17, 2004 | 05:52 PM
Lonnie Pavtis's Avatar
Re: transmission??
I believe the original poster has am M6..... therefore no dipstick.
Remove plug in drivers side of trans & fill w/ fluid until it reaches the bottom of the threads. You can use a small squirt bottle or a screw on tip with a small hose attached to your qt of oil to easily get it in the trans....there is not room for a bottle in the trans tunnel to put it directly in the trans
Old Nov 17, 2004 | 06:17 PM
FryedClutch's Avatar
Re: transmission??
or if you wanna take the really hard difficult but kinda easier way i think that you can remove the shifter and dump it in where the shifter goes
please correct me if im wrong but i believe it works
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
