Transmission
Old Apr 13, 2003 | 12:43 PM
SilverStreak's Avatar
Question Transmission
I just had my 4L60E rebuilt and i got all my lines flushed and another converter. How many qt. of trans fluid should go in? i put 11 and it's just at the bottom of the stick, is that normal? also for 3 days ago it was at propper level when i had that in, i was driving yesterday and my trans started the same problems it was having to cause me to rebuild it... grrr... so i checked the fluid and it is normal color but just low.. what should i do? thanks for reading
Old Apr 13, 2003 | 12:54 PM
funina91ss's Avatar
fill it back up to full and check it will its hot.. and running.. you might of burned up the clutches from running low on fluid...
Old Apr 13, 2003 | 01:00 PM
Well anyidea how it could lose that much fluid in 3 days (aboutr 2-3 qts.) There are no leaks to be seen, last night till this morning no leaks under the car ethir
Old Apr 14, 2003 | 04:30 PM
anyone out there with more ideas? i filled it up so it is at full when hot and running, still have the same problem. The fluid is good too so i don't think i blew a seal or anything... does the fluid change color if you burn a clutch? The fluid smells normal too... any help would be great! thanks again
Old Apr 14, 2003 | 04:59 PM
My94RedZ28A4's Avatar
Check the color of your coolant. If it was green, is it still green? Could be a leak in the radiator causing the ATF fluid to go into the engine cooling system.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
