Trans Question
Old Aug 3, 2003 | 02:49 PM
ZaneO's Avatar
Trans Question
My transmission (under normal acceleration) is not shifting in each gear until about 3500 rpm. When it does shift, it jolts pretty hard. I have 89k miles on the stock A4 trans.
Does this mean that is going out?
TIA
Old Aug 3, 2003 | 02:54 PM
Rich_z28's Avatar
Are you actually able to drive the car up to 3500 RPM or is it reving up to 3500 RPM? It sounds like it is reving then shifting, if so that's why it would be jolting like that. It'd be like neutral droping it.
Old Aug 3, 2003 | 03:02 PM
ZaneO's Avatar
Not 100% sure what you mean.
I am just driving normally, and the rpm's just climb until approx. 3500. The shifts don't go quite as high in each higher gear.
Old Aug 3, 2003 | 03:39 PM
Rich_z28's Avatar
Sorry to confuse you. What I meant was is the car actully putting power to the wheels all the way up to 3500 or is the tranny slipping and the car is reving up the 3500?
Old Aug 3, 2003 | 04:06 PM
ZaneO's Avatar
Ahh. It feels more like the tranny is slipping. Similar to a converter flash, but I have a stock converter. Rpm go up fairly quickly and fall slowly if I let off the gas.
Z28ROC's Avatar
What does it do when you go WOT?
Old Aug 3, 2003 | 04:08 PM
ZaneO's Avatar
I didn't try going WOT. Partly because I don't want to finish the tranny off doing that (if that's the case), and partly because I have a very lean condition at WOT.
Old Aug 3, 2003 | 04:09 PM
Rich_z28's Avatar
It sounds like the tranny is slipping and it isn't shifting until 3500. That would explain why it jolts when it shifts. It's just like putting the car in neutral and reving it up to 3500 then putting it in gear. It's time for a rebuild. I would almost guarantee that when you got to WOT that it's just going to bounce off the rev limiter.
Old Aug 3, 2003 | 04:10 PM
ZaneO's Avatar
That's what I ASSumed, but wasn't positive.
Any guesstimate of how much time I might have?
Old Aug 3, 2003 | 04:13 PM
Rich_z28's Avatar
I'd say not much. Especially if it's slipping under 3500 RPM. When your RPM's are that low and it's slipping, you don't have much time left on the tranny. Things are pretty much shot when it's slipping at those RPM's.
Old Aug 3, 2003 | 04:16 PM
ZaneO's Avatar
It was just really strange because I have not noticed anything until today.
I did some normal driving today and all seemed fine. Then when I was coming home, it started acting up.
Is there anything I can check or look for to tell me for sure?
Thanks for all your help.
Old Aug 3, 2003 | 07:53 PM
Z28ROC's Avatar
How's the fluid level?
A lot of things can affect the trans. Such as the TPS, and VSS. Get it scanned and see what's up. Maybe something simple.
Old Aug 3, 2003 | 08:03 PM
ZaneO's Avatar
It's not the fluid.
I took it for another quick trip around the block and barely made it home. It revs pretty freely and doesn't move anywhere.
Looks like I get a rebuild this week.
No big surprise though with 89k miles.
Old Aug 3, 2003 | 08:23 PM
12SCNDZ's Avatar
Your car is a '93, which means it has a 700 transmission in it. These transmissions are still governor/throttle valve (TV) cable controlled.
It sounds like your TV cable isn't hooked up, or your TV valve (In the valvebody) is stuck.
Start the engine, and snap the tv cable where it hooks on the t-body a few times. Drive the car and see if it helps. Unfortunately, A stuck TV valve is usually a sign of something coming apart in the transmnission.
Frank
Moshbmx1
Feb 17, 2015 10:51 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 13, 2015 09:52 PM
capebuf
Jan 13, 2015 07:22 PM
Lederman1976
Nov 30, 2014 05:21 AM
