Trans-go install problem, please help.
Old Aug 5, 2003 | 12:22 AM
Transamdriver's Avatar
Since the instrucions are lacking severly I pulled out the wrong thing. This one as the pictures shows went ontop of the solenoid with the exposed copper wire. I need to know how it goes back up in there since as soon as I removed the snap ring it fell out and I didnt get to see how it went in. Any help will be greatly appreciated since I will have to get my car towed to have it looked at if I cannot find out for sure how it went in.
Old Aug 5, 2003 | 05:56 PM
Unhappy
TTT
Old Aug 6, 2003 | 01:06 AM
Ken95Z28's Avatar
I have a service manual in front of me and according to this there are two springs that goes with this valve.
Basically there is an inner spring and an outer spring, the first picture that you show is the outer spring. Look for the other spring.
Also to reinstall this you need to flip the valve 180 degrees from what you have in the picture than install.
Hope this helps you.
liamcg97
Nov 25, 2019 05:55 PM
Deadbolt24
Jan 19, 2015 01:29 PM
97SSdude
Dec 31, 2014 07:43 PM
30thZ4C
Dec 26, 2014 05:09 PM
Snake Slayer
Jul 29, 2002 12:39 PM
