Everyone take a look I need it (esp. pros)
Old Aug 4, 2003 | 08:34 PM
S.J.S.'s Avatar
Alright I guess this is it. I just changed a whole bunch of crap on my car. Plugs, belt, oil sensor, fuel filter, gear oil, engine oil, transmount. Took the car out sounded great. Punched it and then it started fartin and I barely made it home. Found a vacuum leak from the PVC valve. Since then the car sounded like it had an exhaust leak. In the last 4 days its gotten louder. Knocking heavily. My brother thinks the engine went. Sounds like it, the oil pressure in under 20 when idling and only at 30 when at 2000rpm. Car is a 97Z A4 with ONLY 79,000Mi.
1st question: What do you all think.
2nd question: I've already thought about a new motor, what 383? I don't even know where to start.
3rd: WHo should I get it from? Crate Motor??????? With what on it. Everyday driver.
Well 1st things first I guess.......
thanks....you guys always help me out. Im greatful.
S.J.S.
97zA4 F#$@&*@!!!!
Old Aug 4, 2003 | 08:44 PM
notstock4long's Avatar
Where is the knock coming from. If you think it is coming from inside the engine, try holding a long screw driver up to it, and put the3 handle part on your ear, to pinpoint where the knock is coming from.
As for a new motor, I would say buy the parts and have it done yourself, you could save a lot of money that way.
Old Aug 5, 2003 | 12:04 AM
S.J.S.'s Avatar
CUMMON GUYS
Old Aug 5, 2003 | 01:00 AM
63SSRagtop's Avatar
Hard to say on that but if you werent having problems before you shouldnt be having them now unless you missed something during the tuneup.. might be pita but the first thing i'd check is make sure you got the plug wires on correctly and that the boots are properly seated on the plugs..
Old Aug 5, 2003 | 01:03 AM
Zerosheaven's Avatar
check engine light on??
hook up a computer and check for codes.
i would say rebuild your current engine into a 383 instead of getting a whole new one.
Old Aug 5, 2003 | 03:03 AM
S.J.S.'s Avatar
Yes check engine light on and it was working fine until I nailed it. Then it went to hell. Found a vac leak but the and car ran better but knocking was there and has just gotten worse
Old Aug 5, 2003 | 03:34 AM
HungryT/A's Avatar
Get the car scanned! It's much easier to find the problem with a MALF code.
Old Aug 5, 2003 | 06:17 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
yeah dude... get it scanned... its probably something fairly minor, considering this started after you changed plugs and wires
Old Aug 5, 2003 | 11:07 AM
S.J.S.'s Avatar
Thanks guys but I'm kinda disapointed. I hope ou guys are right but this knocking is loud as hell and to be honest I don't see how it sould be minor.
Old Aug 5, 2003 | 05:52 PM
S.J.S.'s Avatar
ttt
Old Aug 5, 2003 | 06:03 PM
jchevy's Avatar
Go to autozone and have them read the code, they will do it for free. That is the first thing you need to do, then come back here and post the code. Its stupid to sit here and try and guess, especially when you have a DTC that can be easily read.
Old Aug 5, 2003 | 10:54 PM
1982z28with18s's Avatar
When running is the SES light on solid or flashing? If its flashing then its a misfire. Definitely get it scanned.
Old Aug 5, 2003 | 11:03 PM
EviLZ28's Avatar
I got a question. When the car is warm and you floor it, does the Oil pressure go down as you climb up in RPM's? If it does, The Motor is bad. I just had the same problem in mine and tore it down to find the bearings in the mains where gone.
Old Aug 6, 2003 | 01:36 AM
S.J.S.'s Avatar
thanks everyone...but Evil and 1982 I appreciate the questions.. No the pressure goes up when I gas it. It stays around 20 when hot and goes up to 40 when Im on the r's. And the SES light just came one recently and stays on. I was told so many things but the knocking is getting louder and its LOUD. TOK TOK TOK TOK. My friend said he had the same problem and it was the OPTI I find that hard to believe. I'm finally glad people are givin me input cause I dont wanna buy another motor if i dont have to
THANK A LOT ALL......I REALLY APPRICIATE IT.
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 9, 2015 03:33 PM
