Trans coolers.......
Old Sep 5, 2003 | 03:39 PM
S.J.S.'s Avatar
Does anyone run additional trans coolers? If so where did you mount it and did you bypass the stock one or what?
Old Sep 5, 2003 | 03:40 PM
jkipp84's Avatar
Absolutely! B&M 19k GVW here..
Old Sep 5, 2003 | 04:31 PM
revtime's Avatar
I run a B&M 24.
I run it inline with my stock radiator cooler.
Old Sep 5, 2003 | 09:19 PM
BigEvil's Avatar
Jasper 16000 gvw, in series with radiator, here.
Old Sep 6, 2003 | 12:19 AM
S.J.S.'s Avatar
Hey rev what do you mean inline and where did you mount it?
Old Sep 6, 2003 | 01:54 AM
neil350's Avatar
B&M Super cooler along with the stock.
Old Sep 6, 2003 | 02:05 AM
TreySpeed's Avatar
On permanent vacation
Dont bypass the old one!
mound it in front of the radiator
I got a 30,000# GVW
Old Sep 6, 2003 | 03:52 AM
S.J.S.'s Avatar
how did you guys mount it? With what?
Old Sep 6, 2003 | 03:57 AM
TreySpeed's Avatar
ZIP TIES!
Old Sep 6, 2003 | 05:08 AM
RacinLT1's Avatar
i have a B&M,used the zip ties that go through the radiator to mount it. it is working in conjunction with the stock 1.
Old Sep 6, 2003 | 08:05 AM
S.J.S.'s Avatar
Did you guys notice a difference? Do you run gauges? Is it really necessary, especially for my mods below?
Basically then you run the line from the cooler to your after market one then from there to your stock one?
Old Sep 6, 2003 | 09:01 AM
TonyJ's Avatar
Summit has the B&M on sale right now. Mount it up front, near or on the radiator... I've got the 24k Run it in series with the stock one.
TJ
Old Sep 6, 2003 | 02:52 PM
revtime's Avatar
I mounted it in front of the radiator, I have no AC so I had lots of room.
I cut off the end of the top line going to the rad and ran my cooler line straight into it, I did not have to use any of the brass couplers that came with the B&M kit. I used one of those for my TB coolant bypass.
Old Sep 7, 2003 | 05:06 AM
S.J.S.'s Avatar
Everyone seems to mount them in front of the radiator. Did you guys run into problems installing it? Was it difficult?
Old Sep 7, 2003 | 05:21 AM
jkipp84's Avatar
The cooler is a very easy install. The moderator of this board has an install guide on his site - here you go.
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 23, 2015 12:59 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
