Trans Am guys w/ K&N FIPK, where to mount headlight control module?
Old Jul 8, 2003 | 04:35 PM
Zack's Avatar
I just finished installing my FIPK, but I couldnt figure where to mount the module. Its sitting next to the intake tube behind the headlight for now.
Old Jul 8, 2003 | 04:36 PM
TheHeadFL's Avatar
Thats where mine is.
Old Jul 8, 2003 | 04:40 PM
bandit1's Avatar
Same here!
Later,
Mike
Old Jul 8, 2003 | 04:44 PM
95 WHITE TRANS's Avatar
Same here.
NICK
Old Jul 8, 2003 | 04:51 PM
IrocManiac's Avatar
I'm glad I read this considering I'm going with cold air kit soon...possibly k&n or LPE...
Old Jul 8, 2003 | 05:34 PM
Cman's Avatar
The hdlt. control unit is mounted originally on top of the small air intake tube (the short piece that connects to the air box and has the small opening that the engine gets air from originally)
That piece comes apart from the OE airbox and can be reinstalled in its original location so you have a place to attach your hdlt. control unit. The K&N tube will go right next to it through the plate that comes with the air intake.
That's how I did mine, holds the control unit just like factory.
Old Jul 8, 2003 | 05:37 PM
Zack's Avatar
i think i get what you are saying, but the air box thingy wont go back into place without taking the K&N air tube out, and I am NOT doing that, PITA the install was
Old Jul 8, 2003 | 05:57 PM
Cman's Avatar
The air box thingy needs to be in place before you bolt down the plate that the air intake tube goes through. The bolt that holds the plate will also hold the air box piece securely.
Old Jul 8, 2003 | 06:15 PM
TheHeadFL's Avatar
No consideration needed, man, just buy one, any one.
Old Jul 8, 2003 | 06:33 PM
DamianLT1's Avatar
I slapped my on the fender wall with dual sided tape.
Old Jul 8, 2003 | 08:31 PM
apick42's Avatar
Thumbs up headlight module
the k&n kit comes with doulbe sided tape this is so that the module can be mounted below the relay box and still give you access if you have to unplug the unit. i have a 93 and that is
how the install showed it.
CaRParts102
Dec 6, 2014 08:45 AM
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Red97LT1
Aug 7, 2002 05:45 PM
