Tranny wiring (part2)
Old Jun 30, 2003 | 08:38 AM
slmdgmc's Avatar
Alright so far with my m6-a4 swap I have totally rewired the 13 pin tranny connector from the computer. No problems there.
Now there are 2 connectors on the side of the tranny where the shifter cable routes to on the drivers side from the dash. There was a 4 pin connector, but I traced those wires to a firewall plug that I found on the passenger side. Now there is a 7 pin connector that I am confused about It has a purple wire in it that goes to the starter relay for a ground (so car wont start in anything but park or neutral), a large yellow wire, 2 small light green wires, a pink, a small yellow, and a black. If anyone has a diagram of can look in a factory service manual for a 95 or 96 car with the 4l60e, it would be much appreciated. This is actually on my truck (96 c1500), but it should be the same cause its the tranny from the truck. This is the last thing I need to do before I can finally see what the lt1 can do in my truck
Old Jun 30, 2003 | 08:53 AM
AlexA's Avatar
That cluster of wires (big yellow/green/etc) sounds like the P/N switch plug. It controls quiet a number of things. You REALLY need a Helms.
-Alex
Old Jun 30, 2003 | 08:56 AM
slmdgmc's Avatar
Yea I have a crappy haynes manual now, but I need to get this wired up by today so that we can finish my install. Are helms manuals available in bookstores?
jmadoll
May 27, 2015 07:13 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
siguy
Nov 27, 2014 10:07 AM
