tranny temp gauge on a M6???
I have a autometer tranny temp gauge...and I just did a m6 swap...and I was wondering can I get it to work on the m6?? like take out the drain plug...cuz there is always fluid there and readuce it down untill my sensor fit in....would that work??
LMK
matt
LMK
matt
Re: tranny temp gauge on a M6???
LMK
matt
LMK
matt
Yeah it will work. When you got the guage new it shoud have cam with 2 fitting and the sensor. One fitting has a hole that the sensor will screw in to. It directly replaces the M6 drain plug on the passanger side of the tranny. HTH
Joe
I have a trans temp gauge in my m-6. It's in the drain hole in an adaptor fitting. I already had the gauge so I figured, why not. It slowly builds up heat in traffic in the summer and can get to 190-200 deg. F. finally. Usually, it's a lot less.
well lets see...before my a4 went out it was pegging the needle at 250 ehhe but it is supposed to run round 180 ish correct me if im wrong im not sure.
Where did you mount the guage? I have one too but the cable for it is only like 4-5 feet long so it seems that would limit you a bit.
Magenta_Hearts
Mar 29, 2017 08:54 PM
I had a tranny temp gauge on my A4. Im going to use the drain plug "hole" like you said.
