tranny problem, anyone know if I need a rebuild?
I have lost second gear. This happened after I changed the fluid, everything was fine for about a week and then second gear just went away. I have a Transgo shift kit installed in the tranny and it worked fine for 50k then I changed the fluid and this happened. A performance rebuild is rather expensive and was just wondering if any of you guys might have expierenced this kind of thing. First, third, and fourth gears are fine and it will shift into second it just won,t pull
Any suggestions?
Any suggestions?
I have had friends try the Trans X fluid (miracle fluid) and the trans works. Don't ask how, but I have seen it first hand. It is supposed to release stuck valves and the sort----It only costs about 5-7 dollars, might help. Also, the last time you checked the trans, did the fluid show any signs of metal shavings, if it did, then you might need to find a swap or rebuilt it----this gets expensive and is a pain. Hope I helped.
Sergio
Jan 27, 2016 04:27 PM
importkiller94
Jan 17, 2015 09:03 PM
