stock ignition coil
Old Feb 20, 2003 | 08:12 PM
ProchargedZ's Avatar
stock ignition coil
I have a 96Z. I bought a MSD coil and an adapter harness to plug into the stock coil harness. I made sure the coil was a single connector for the 96 + models and the harness adapter was for the same. My stock coil has a 4 pin connector in it and the adpter is for a 3 pin.... I am missing something?
Old Feb 21, 2003 | 12:37 PM
Old Feb 21, 2003 | 01:30 PM
The ICM has four terminals but the coil should only have 3 and be a single connector.
Old Feb 21, 2003 | 01:36 PM
94 NO TOP Z's Avatar
Is it harness 8877? If so that is to wire in a MSD box not, a coil. You shouldn't need any adapters if you got the '96 and up coil. It should plug right up.
RUENUF
May 25, 2016 08:10 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
