Tranny Cooler Line Question
Old Apr 27, 2003 | 09:23 PM
ChevyCamZ28's Avatar
Guys,
I'm doing a swap from an M6 to an auto and I know that the M6 doesn't have cooler lines. But my question is does the radiator in a 94 Z have the provisions for the cooler lines? Maybe they are just plugged up? I would go out and look but the car isn't here (working on it elsewhere) and have to know if I should order a heavier duty tranny cooler to run by itself rather than in series with the radiator...
Thanks!
Mike
Old Apr 27, 2003 | 09:26 PM
94FlamdS10Blazr's Avatar
im just running a Summit racing heavy duty tranny cooler only. I need to hook up the tranny temp gauge I got so I can see if its working ok. I havent got the rest of the vehicle running right to see
Old Apr 27, 2003 | 10:51 PM
They did make 2 different part numbers for tank with and without the coolers. Probably a factory M6 car did not have the cooler in the RH radiator tank. An added aftermarket cooler would work just fine, though.
Sergio
Jan 27, 2016 04:27 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
mattszm6
Dec 14, 2014 07:09 AM
RedLineRev
Jan 23, 2003 03:51 PM
