Traction control-what do you do with the 3 brake lines.
We installed a Powerdyne unit on a 97 Z we had to remove the ASR unit for the blower to fit. What do we do with the 3 brake lines that connected to the ASR unit. What part is needed?
I got no response in the general section, so I'm trying here.
Scott
Scott
Re: Traction control-what do you do with the 3 brake lines.
Originally Posted by BlackDog
ttt
You can just put a y-adaptor of some type on those lines and run one back or go ahead and run the one line from the ABS modulator all the way back. Whatever is easier or is doable with the blower.
14
Aug 11, 2015 12:03 PM
