traction and 410s what ta do
Old May 25, 2003 | 12:35 AM
Dmx4ever3's Avatar
I got a CENTERFORCE dual friction and its very different then my stock it grabs so hard I have no traction at all its the 410 gears that are now throwing me off I need traction what do I do. I got a south side sup kit for only $250 but its costs 3-400 to install and i was told the lift bar are not a good type so IM going to return the kit and buy parts like subframe con. and lower control arms what kinds should i get where should i get it and what else what i need for the mods i have and does anybody have anything they may want to sell?? to me??
Old May 25, 2003 | 08:06 AM
limige's Avatar
well, when i swapped mine out with the new rear it seems to hook pretty well. i've got a limited slip now instead of a posi, not sure if thats why or not but really, it hooks well, i've got stock size yokos on the rear.
Old May 25, 2003 | 10:31 AM
MYT30TH's Avatar
I have no problems with traction at all with the suspension mods in my sig. w/ 4:10's My car hooks really well on the street .I run with my Nitto 555R's. I still need to get to the track sometime this year to put the new clutch & gears to the test.
Old May 25, 2003 | 05:03 PM
Dmx4ever3's Avatar
again am asking can some one help me in what to get and explain what parts do what in sup work thanks
Old May 25, 2003 | 05:12 PM
atljar's Avatar
No suspension is worth much without tires. Nitto Drag radials will allow you to hook without touching the suspension.
Old May 25, 2003 | 05:17 PM
Dmx4ever3's Avatar
well where do i get them how much are they and then what after i was going to save to do rims and then get tires but whats next and what size would i want to use and will they fit with a convertable?
Old May 25, 2003 | 09:16 PM
my94blackz's Avatar
I agree with the lca's! I have the edelbrock rear lca's and panhard which is good for cornors, I also have hotchks front sway and stb. Im lowered also. Now with that said i have a m6 that had 4.10s and with 255/50 street tire i didnt have much trouble hooking up at a 1500 drop, hope that helps.
Old May 25, 2003 | 09:27 PM
atljar's Avatar
1500??? Jeeze, heated Nitto DRs i was dropping at 6000 with 4.33s.
Anyways, you can buy them at anyplace that carries Nitto tires. They are sized just like any other tire, so buy according to rim size. They are 160ish per tire, you only use them on the rear. Expect to get 12-15k miles per tire.
Old May 25, 2003 | 09:44 PM
my94blackz's Avatar
I said STREET tire, at the track with my nittos i go at 5000. but on the street i went at 1500 with regular comp ta's.
Old May 26, 2003 | 05:39 AM
Dmx4ever3's Avatar
ttt bump
Old May 26, 2003 | 11:40 AM
atljar's Avatar
Nittos are my street tire Anyways, i was making a point about how well they hook, no more no less, sorry if it came off as attacking you, wasnt meant that way, just a little sarcasm.
Old May 26, 2003 | 11:43 AM
my94blackz's Avatar
I wasnt mad i jus clarified . With my 16's i was running the comps but with my 17's im running a 315 nitto haha. No worries on making me mad.
Old May 26, 2003 | 01:46 PM
TedH's Avatar
Nitto drag radials can be used successfully on the street with little or no problems. With any hugh traction tire expect them to wear quickly and not be very good in the rain. I know they are better than the BFG's in the rain but rain tires have more tread depth... Otherwise they handle fine. Do other suspension stuff after you can quantify the benefit of the tires. In other words, make one change at a time and quantify the improvement or lack of improvement. Without decent tires you can waste a lot of money on suspension mods.
Boss002
Jul 24, 2015 10:47 AM
Javi Fierros
Jun 10, 2015 03:35 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
brentasan
Jul 7, 2002 08:59 PM
Jay-mak
Jun 14, 2002 05:40 PM
