traction
Old Jan 1, 2004 | 11:19 PM
badblackta's Avatar
traction
I have a major problem with traction with my trans am. It is a 1993 with long tube headers, true dual exhaust, and a rebult transmission with a shift kit and a 2000 stall torque converter. I put brand new kuhmo ecsta supra tires on it and it still spins like there is no tommorrow. I think some et streets will fix it but I could use advice. Any suggestions?
Old Jan 1, 2004 | 11:24 PM
QCKZ28's Avatar
drag radials helped me tremendously
Old Jan 1, 2004 | 11:30 PM
badblackta's Avatar
what kind of drag radials do you have and do you have any suspension work done?
Old Jan 1, 2004 | 11:31 PM
Antz97ZNJ's Avatar
2000 stall converter??, you sure you dont mean 3000, 2000 is lower then the stock stall....Nittos and lca's should take care of your problems
Old Jan 1, 2004 | 11:34 PM
QCKZ28's Avatar
actually 2000 stall is just a tad higher than stock. i think the stock convertor is around 1700-1800.
jesse
Old Jan 1, 2004 | 11:51 PM
badblackta's Avatar
well it is a essentially a stock converter but it will hold at a little above 2000 rpm before the tires break loose, that is why I say 2000 stall. So lower control arms and nittos? I heard nittos were good on the street and crappy at the track?
Old Jan 1, 2004 | 11:57 PM
QCKZ28's Avatar
my stock convertor would only "foot brake" to 1000rpm before the tires loose, now with my vigilante 2800 it will only "foot brake" to 2000rpm.
"foot braking" is not an accurate way to measure stall speed.....
i have drag radials for street driving, and will be using ET streets for the track, to keep from burning my drag radials off.....
people cut pretty good times with DR around 1.7-1.8
jesse
Old Jan 2, 2004 | 12:10 AM
badblackta's Avatar
Do you know what size et street will fit on the stock wheel?
Old Jan 2, 2004 | 12:12 AM
QCKZ28's Avatar
for a 16" stock wheel (16x8) you have a choice
26"x10.5"x16"
26"x11.5"x16"
i went with the 11.5" version personally, but the 10.5" is plenty of rubber....
jesse
Old Jan 2, 2004 | 12:22 AM
badblackta's Avatar
thanks QCKZ28. I will look into the et street and probably pick up two more stock wheels so I can use them for the track. ran a 14.16 at 96mph with 2.02 60-ft. stock. have not been back since headers and stuff, so my et should drop a good bit with et streets.
Old Mar 7, 2004 | 05:58 PM
Myxtreme1's Avatar
26"x10.5"x16"
26"x11.5"x16"
jesse
What brand are those and where did you get them from?
Old Mar 7, 2004 | 09:59 PM
QCKZ28's Avatar
Mickey Thompson ET Streets from summit or jegs
jesse
Old Mar 7, 2004 | 10:07 PM
Green95Z28's Avatar
I used to have the same problem at the track with my 93 M6. I switched from running a best ever of 13.6@102 w/ a 1.98 60' (once)on 17x9.5 SS wheels to running a consistent 13.2s@103 with LOW 1.8 60's on a set of 16x8 stock 5 point wheels (not the salad shooters) I picked them up at the junkyard for 100 bucks for the pair and I run 26x10.5 ET streets. Those tires will hold against an auto no problem. You could go with 11.5s and would have better traction but they are heavier. With my motor setup I can't over power my 10.5s.To shed some light on just how good they are, a couple of friends of mine have turned 10s on my tires with mid 1.5s in the 60' in automatic LS1s . When I put the random tech torque arm and lower control arms that also helped A TON as with sub-frame connectors did too.
Boss002
Jul 24, 2015 10:47 AM
Javi Fierros
Jun 10, 2015 03:35 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
brentasan
Jul 7, 2002 08:59 PM
Jay-mak
Jun 14, 2002 05:40 PM
