Track times...what do you think?
Old May 7, 2005 | 03:58 PM
Jameslt1TA's Avatar
Well i just got back from the track for the first time. And before you all roll on the ground laughing lemme tell you that i was at 3500ft, and my car is only shifting at 6200 because i have the stock spark plug wires and im arching over at higher rpms(i think) and it doesn't pull much past 5500 but i dont think there is valve float. Im also on the stock stall and terrible khumo street tires. I also wasn't allowed to run on the normal part of the track, i had to go off on the side so i wouldn't mess it up or something. well heres some of my runs. Also it was my first time at the track.
spun thru first and shifting into second on every run.
tires at 35 psi
10:01 am
r/t .870
60' 2.459
1/8 9.707
1/4 14.640
mph 101.84
tires at 35 psi
best run
10:33 am
r/t .597
60' 2.395
1/8 9.188
1/4 13.988
mph 104.26
tires at 25 psi
10:52 am
r/t .721
60' 2.385
1/8 9.468
1/4 14.394
mph 101.76
run with a built 1.8 liter turbo honda running slicks
tires at 25 psi
r/t .625 r/t .155
60' 2.404 60' 2.201
1/8 9.267 1/8 9.345
1/4 14.138 1/4 14.401
mph 102.62 97.27
As my r/t shows... i lost i was about a half car behind him at the end of the 1/4...the only honda at the drag strip and i lost to him...errr
tires at 20 psi last run for me
r/t .597
60' 2.399
1/8 9.237
1/4 14.072
mph 103.14
Well it's obvious that i need to get my 60' down...but i just couldnt i usually just left off of idle too.
O well i guess ill go back when i get some tires and new plug wires and shift it a little higher.
James
Old May 7, 2005 | 04:00 PM
madwolf's Avatar
Re: Track times...what do you think?
Your 60s are killing you.
You could run a medium to low 13 if you got a decent 60'.
Old May 7, 2005 | 04:13 PM
Jameslt1TA's Avatar
I think that there is a problem with the car too because the 60' on my 3rd run is better than my second run, but the car trapped 3 mph slower and was about .4 slower. It seems like it misses sometimes but not others.
Old May 7, 2005 | 04:16 PM
jdizzell's Avatar
I think you need more practice and tires. With the mods in your sig you should be atleast mid 12's to low 12's. I have a smaller cam, stock heads, full exhaust w/shorties, 3.42 gears and E/T streets running best time of 12.8, but consistent 13-13.1 times.
Old May 7, 2005 | 04:24 PM
Jeremy95TA's Avatar
Judging by your mph you should be running 13.1-13.3.
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
